Recommended config.pro and detail.dtl Settings for Model-Based Definition in Creo?
OM_10919029
6-Contributor
I'm using Creo 7.0.2.0 and working on implementing Model-Based Definition (MBD) at my company. Are there any specific config.pro or detail options that should be set or adjusted to better support MBD workflows?
2 REPLIES 2
Hi @OM_10919029,
Thank you for your question.
Anurag
Hi
I am on Creo 10. Hence, wont know the specifics to Creo 7.
However, you may try this...
combined_state_type --> semi_mbd
Can't see any other change in config.pro or in config.dtl.
