Redefine Ordinate Dimension Origin Zero
wfalco
On 6.0.
Is it possible to redefine the ordinate origin of zero? See attached.
I can redefine each dimension off zero by right mouse clicking. But no options to relocate zero.
Do they all have to be done over?
WayneF
2 REPLIES 2
KenFarley
(To:wfalco)
I've never had much luck trying to change the origin for a set of ordinate dimensions.
My theoretical method for next time I try would be:
(1) Figure out which of the dimensions was created first, i.e. is the one that was toggled to ordinate to start the set.
(2) Try to redefine attachment on that dimension. I don't know if it will let me do this. It might just let me change the non-origin half of the dimension.
(3) If that doesn't work, maybe toggle that dimension back to a "normal" dimension, then redefine its attachment.
(4) Once I've redefined it, toggle it back to ordinate.
I've tried a variety of things in the past, but always given up and deleted all the dimensions and recreated them with the new origin. So much for efficiency.
Ken,
I liked the idea of trying to change to normal. But No idea how to do that.
I doubt it would work. But was willing to try.
Can't redefine the zero. Dumb.
By the way. These are CREATE in drawing dimensions. I forgot to mention.
I was trying to help out a work buddy.
Happy 4th!
Wayne
