Regenerated an Assembly, Saved, Model is not Regenerated
wbottis
In CREO 5, I regenerated an assembly model, saved, and was prompted to regenerate?  Then, I clicked OK and still had the regenerate icon showing in the lower-right corner of the graphics window.  Can someone explain what is going on with this regeneration obsession by Creo, why isn't it satisfied, and why isn't it telling me why it isn't satisfied?  Thank you.
3 REPLIES 3
it looks like your assembly contains circular loop which causes reported behaviour.
  • enlarge message area ... maybe you will see some important information
  • the problem may be hidden in relations
Martin Hanák
wbottis
(To:MartinHanak)
I think you are correct, Martin.  I will need to open each part and investigate the relations in each.
Dale_Rosema
(To:wbottis)
This may not help, but this is some of the things that I ran into in Creo 4.0:
https://community.ptc.com/t5/Part-Modeling/Regenerated-Family-Table-Instances-Part-2/m-p/595097
