Remove Suffix from all parts
manny1
3-Newcomer
I was able to add suffix to all parts using "set new name" in windchill. I've attached screenshots below.
My question is how would I go about if i had to remove the new suffix from the name and go back to only the base number?
pausob
(To:manny1)
Have you tried the "reverse" of your original change pattern? Like this:
*_suff.*   -->   *.*
4 REPLIES 4
BenLoosli
(To:manny1)
Are the base numbers the same?
Are the suffix numbers the same?
An example of your part naming would help.
manny1
3-Newcomer
(To:BenLoosli)
The base numbers will be different but the suffix are the same.
for example 123456_suff  >>> 123456
                    245365_suff >>> 245365
so different base numbers that i want to keep but knock off the same suffix at the end.
Thanks hope this helps
pausob
(To:manny1)
*_suff.*   -->   *.*
manny1
3-Newcomer
(To:pausob)
Sweet!! Thanks it worked!
