HI all.
When flipping the arrows on a dimension the leader line remains between the arrows - see attachment.
Any idea what the setting is to remove this?
@SteveJI wrote:
Thanks Martin.
I want the text to remain above the leader line but not the line inbetween the arrow heads (when arrows are flipped)
I understand you but I guess this is not possible.
you can set detail option default_lindim_text_orientation horizontal
Thanks Martin.
@SteveJI wrote:
Thanks Martin.
