Rename balloon note
Ketan_Lalcheta
Rename balloon note
Hello
I hope one cannot rename balloon note in drawing. It's name is auto generated and not in control of user. However, I could see different nomenclature for balloon note. One having prefix as balloon note and others having prefix as balloon_note. See attached image for reference.
Actually my sole purpose of this query is to identify balloon note from name of the note using toolkit API. However I just want to confirm that this name is not in user's control (only Creo internal is giving this name) and will have always name as balloon_note or balloon note.
@Ketan_Lalcheta  it is possible to rename a balloon note from Creo Drawing detail tree.
1) Double click on the balloon note annotation name listed in the Detail tree (OR)
2) Select the annotation in the detail tree and push F2 key
The naming of balloon notes should be same as per the rules applicable to name any feature or parameter in Creo.
