Repeat Regions for Wire Harness
mo185028
3-Newcomer
I created a repeat region for a wire harness, details include: From/To Connectors and Pins, Wire specs such as color gauge, length. All data are populated except for the From/To Pin names (harn.run.cond.from.pin.name). How do I resolve this? Thank you!
1 REPLY 1
oull
(To:mo185028)
Normally the entry port for wire must be linked to a pin then &harn.run.cond.from.pin.name will fil in the from/to pin name in the repeat region Table As described in Article - CS133154
https://www.ptc.com/en/support/article/CS133154
Please refer to Creo Help about how To Assign an Entry Port to a Pin Number :
http://support.ptc.com/help//creo/creo_pma/usascii/index.html#page/electrical_design/cable/About_Entry_Ports.html
http://support.ptc.com/help//creo/creo_pma/r8.0/usascii/index.html#page/electrical_design/cable/About_Entry_Ports.html
and to this video Demo at:
https://support.ptc.com/images/cs/articles/2018/09/1536220508kdQi/demo.mp4
Regards
