Replace Family Table component in assembly with non-family table member
al3
6-Contributor
6-Contributor
Have a piece of hardware that is used dozens of times in an assembly and will only allow me to replace it with a family table member, is there a way to be able to replace it with a "Non-Related" component?
4 REPLIES 4
Tdaugherty
(To:al3)
Try using the replace by unrelated command. Here's a link to some documentation. It's the same command you would use to replace by family table but you select the unrelated option instead.
http://support.ptc.com/help/creo/creo_pma/usascii/index.html#page/assembly/asm/asm_six_sub/To_Replace_Component_with_Unrelat_Component.html
al3
6-Contributor
6-Contributor
(To:Tdaugherty)
Right, that option is grayed out, trying to figure out how to bring in the part as just an instance instead of being a part of the family table, not sure the best way to go about it
BenLoosli
(To:al3)
An instance is always a member of a family table.
Is the new part a member of a family table already or should be a member of an existing family table?
Replacing a component with a family table member is always cleaner and easier.
What kind of component are you replacing?
al3
6-Contributor
6-Contributor
(To:BenLoosli)
Think I found the issue, there is some sort of flexibility or varied item within the part, I need to remove that before I can replace it with a "Non-related" component I believe.
