Replace "Filename" in the whole UI by a configurable string that can include one or more parameters (User-defined + Internal)
_Marc_
Current situation
  • The Filename is shown in the UI
  • Common Name (PTC_COMMON_NAME) is planned since 2004 to have more applicability in the UI: ".. For Wildfire 3.0 (or beyond), it is planned that the "Common Name" will have more applicability in the Pro/ENGINEER User Interface." (see https://support.ptc.com/appserver/cs/view/solution.jsp?n=124152)
Idea
Replace "Filename" in the whole UI by a configurable string that can includes one or more parameters (User-defined + Internal).
UI elements that should be configurable (uncomplete list):
  • Model tree (the first - currently non configurable column)
  • Layer tree
  • All "Pick From List" dialogs
  • Title bar
  • Message log
It would be good to have the configuration of all possible UI occurences of "Filename" in one place. Config.pro options defining the strings should start with the same name, e.g.:
UI_object_identificator_ + <name of the UI Element>.
Examples
Values for configurable string that replaces "Filename"
Example result
MATERIAL_NO + " " + SHORTDESCRIPTION_LANG1 123456789 Sheet
MATERIAL_NO + "-" + SHORTDESCRIPTION_LANG2 123456789-Blech
SHORTDESCRIPTION_LANG1 Sheet
MATERIAL_NO + " " + PTC_COMMON_NAME 123456789 Sheet
SHORTDESCRIPTION_LANG1 + " (" + PTC_MATERIAL_NAME + ")" Sheet (S235J2G3C)
FILENAME 53464523456_sheet.prt
2 REPLIES 2
Wyndorps
2-Explorer
(To:_Marc_)
see here
http://communities.ptc.com/ideas/4708
I think it is the same idea.
_Marc_
(To:_Marc_)
Compared to Create an config option to display the ptc_common_name in user interfaces) I'd like to see implemented a more general functionality and a  configuration for the different existing UI elements that contain the  "Filename".
