Replace
ptc-169947
Replace
Hi all,
Not sure if anyone out there's still on 3.4 and Wildfire 4, but if so, we're seeing an issue where if you use the replace functionality in an assy in WF4, the original part that was replaced still holds a dependency to the assy in Intralink even though it's no longer in the assy.
Has anyone seen this? If so, any fixes or suggestions?
Stefan
If I trust my memory you can break that dependency in the Reference Viewer inside Wildfire 4.
Show dependencies for the assembly, find the replaced part, RMB and select Break Dependency.
/Bjarne
Bjarne is correct. I have seen this too, sometimes Pro/E retains odd relationships between parts which have nothing to do with each other anymore. I believe the path is Reference View under Tools. You should see a red "X" beside old references which can be broken.
You may also want to set the config.pro option "remember_replaced_components" to "no". This will uncheck by default the "remember these components" checkbox in the replace dialog box. It is that checkbox which creates the undesired reference - some kind of internal interchange assembly for replaced components.
rmast
(To:ptc-169947)
The config option availablility depends on build code WF4 M120 or later.
