Replacing dimension value with a letter
imorgan2019
8-Gravel
I'm trying to replace a numeric dimension with a letter to produce an assembly drawing with a variable dimension. I haven't been able to find a method to remove/hide the numeric value of the dimension, can anyone help?
  • Edit the "Dimension Text"
  • Replace @D with @O (change the D in an O)
  • Type anything directly after the O
The @O will hide the numeric value of the dimension.
3 REPLIES 3
1.] shown model dimension (default d* name can be changed to custom name, eg. length)
You can edit dimension and change @D to @S
2.] dimension created in drawing
You can edit dimension, change @D to @O followed by custom name
Martin Hanák
Thanks everyone for your help, problem solved.
