Replacing part in assembly
STBE
When starting Creo 5.0.1.0 for the first time and replacing a copied part in assembly, I get an error:
"You must use Standard mode to redefine this dashboard feature.":
After closing/erasing and repeating the steps, the replace suddenly works. How can I resolve this error?
The only thing that has changed in the second replace is the PRO_PART ID from 3, to 524291.
STBE
(To:STBE)
Resolved error by removing SWITCH_TO_MDL command.
lhoogeveen
(To:STBE)
Might be worth contacting PTC Support to report the issue - could be a bug. They may already have a fix in a higher build code or would need to know about it to fix it.
STBE
(To:STBE)
