Requirement of a template for generation of injection molding feed screws
psimha
I would like to know, if there are approaches to design a template in Creo 2.0 parametric for a feed screw (An Injection molding machine feed screw). There are about 5 different profiles of feed screws for which a single template should hold good.
When the user keys in the values into the template, the feed screw 3D model in Creo 2.0 parametric should generate automatically.
Best regards,
Prasanna Simha T.R
check out this video
It should give you a good idea of a template generation
Taking Control of Helical Shapes - YouTube
Hello Ron,
Thank you.
Prasanna
