Hallo,
how can I restore (or even create?) default datum planes ? (RIGHT FRONT TOP...). I have this assembly and I don't see them:
thanks
Assuming your datum planes are shown as Steven described and they still are not present.
Go to Model tab, click the down arrow by datum and select default coord system.
Drag the default coord system to be the first feature in your model, you'll have to move the first component down below the coord system.
move the "insert here" arrow to just below the default coord system so every
without anything selected, select create datum plane icon
That should automatically create your default datum planes, you will have to rename them according to your standards.
Tomasso,
I think that the assembly was created as Empty one. I guess that you cannot create default datum planes and put them at the beginning of the model tree. Maybe someone knows some trick ...
Martin Hanak
Hi Martin,
yes it was probably like you said. But I don't know why, these planes have suddenly disappeared (I am sure they were present before).
Bye
Thought I would clarify with images.
Assembly has no default datums, probably created empty as Martin suggested.
1. Create default coordinate system under the dropdown arrow by Datum in the model tab, select detault coordinate system.
2.Move the default coord system to be the first component. I selected all components in the model tree and drug them below the new coordinate system.
3. Drag the insert here to just below the new coord system.
4. With nothing selected, push the plane creation icon, it will create the 3 default datums
5. rename the default coord system and default planes to your standard.
6. Cancel the insert here
Hi Stephen,
thanks for your solution, indeed I made it through as you indicated me. You meant that assembly do not have datum planes? At this point therefore I think that those I see by default are deriving from the start part...
bye
Tommaso,
Maybe this can work,
If you need them in the model tree, maybe you should post another question.
Hallo Ruben,
thanks for your reply. No, I do not need them just in the model tree, but just them to be present.
In fact you can see below that in the layer tree I don't have any mininal sign of the original datum planes, but only of the three planes I have added in the way Stephen suggested. See both above under "01_ASM_ALL_DTM_PLN" (where C0006 is just the bearing), and below under the voice "piani" (that is the Italian of "planes").
bye bye
Tommaso
