Restricted value parameters with access=full
Grace2K
Hello
I have this restricted value parameter definition set in Creo 8.
{ Name = TOLLERANZA_GENERALE
Type = string
default = 'ISO 2768-mK'
Enum = {
'ISO 2768-mK',
'ISO 2768-fH',
'ISO 2768-cL'
Access = full
I thought that with the option "access=full" you could change the entered value as you wish in Creo with the possibility of choosing a value not included in the list, entering it from the keyboard.
But it seems that this is not the case. The only possible values ​​are those of the list.
So what is the meaning of "access=full"?
@BenLoosli thanks for the advice.
Now I understood that the list of values ​​is untouchable when it is defined in the restricted parameters file but it cannot be changed even through the parameter properties page in Creo: all the options are greyed out. See image below.
While it seems the "access=full" or "access=locked" option affects only the erasability of the parameter itself.
If it's full you can delete it, if it's locked you cannot.
4 REPLIES 4
please ask PTC Support.
Martin Hanák
BenLoosli
(To:Grace2K)
You should be able to add an additional values to the list and then choose that for your parameter value.
You cannot manually enter a value directly in the parameter field.
Article - CS320648 - Is it possible to enter the value other than one listed in restricted parameter list in Creo Parametric? (ptc.com)
Hi @Grace2K,
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Catalina
PTC Community Moderator
PTC
