Restructuring a multi-level assembly into a single-level assembly
ProFeature
Hello community,
Is there an automatic method for restructuring a multi-level assembly to a single-level assembly?
Hi @tbraxton and  thanks for your reply!
I just wanted to point out that your response doesn’t really address the specific need I raised in my question. Rather, it confirms that Creo currently lacks a built-in automated method for flattening multi-level assemblies into a single-level structure while preserving parametric relationships.
After further investigation, I realized that the Reconstruction operation best suits my needs. I selected all the components and chose the target assembly to move them into.
Also, I’m not sure why Inspirable Assemblies were mentioned—they seem to serve a different purpose and don’t appear to be relevant to the restructuring functionality I asked about.
tbraxton
(To:ProFeature)
AFAIK there is nothing available out of the box that would do this in an automated fashion. Starting with Creo 8 inspirable assemblies were introduced which may be relevant to your needs so investigate that functionality if you have not already done so.
Shrinkwrap functionality or export/import can be used to flatten assemblies, but I am doubting that these options would meet your stated goal as the results here are not fully parametric Creo data structures but dumb geometry representations.
About Inseparable Assemblies and Embedded Components
Involute Development, LLC
Consulting Engineers
I think you meant to say "Restructure", not "Reconstruction".
Good catch, @ArnoldCollett - thanks for pointing out that typo!
Much appreciated 🙌
