Hadn't had time until lately to investigate playing with this again. It's a shape with a single side, and a single edge. I managed to fix it and get nice smooth tangencies, and the exact geometry I wanted (rate of OD change, rate of unfold to refold), and make sure the unfolded width was the same length as the circular section circumference. I just added a thickness to it so I can 3D print it.
Nice one!
'Sup Antonius! I sent you the real file via e-mail....unless it's changed. If so, lemme know. Hope you've been well! ![]()
Somewhat surprised Antonius was the only one to comment on this.......
The rest of us were overwhelmed and just sat back in awe.
Yep, pretty much! ![]()
LOLZ! Geez, usually that only happens when I do something colossally stupid (again...)!! ![]()
