Rotary table support
NiloyGuha
Participant
Hi Gurus,
Couple of questions:
Does Pro/ENGINEER Production Machining Option ( which is for 3 axis milling)
support rotary table movement?
Also does anyone have a postprocessor for Fanuc 18M & 21M? Is Fanuc 21M used
for 5-axis machining?
TIA,
Niloy Guha
Niloy,
To answer your 2 questions: Does Pro/ENGINEER Production Machining Option (
which is for 3 axis milling) support rotary table movement?
It supports up to 4 and 5 axis positioning only milling (not simultaneous
milling) and 2-axis turning.
Yes, I have several posts, but you really have to know more than the
control. I can give you a really good deal creating them for you. I do
this for a living and will beat anyone's price to get you setup with post
processors.
Sincerely,
Kent Hanson
PostPro
Pro/NC and GPost Services
27011 Washington Blvd
Edwardsburg, MI 49112
T 269.663.5515
M 574.286.8145
_____
Kent,
Does that include me? 😉
Fred Nemecek
Austin N.C., Inc.
512/458-1112 x19
_____
Thanks to all those who replied. What I have understood is that PMO supports
4 & 5 axis positioning motions. But simultaneous rotation & machining is not
possible.
To further give clarity to my question I have attached an image of the part
to be machined.
My client is buying a Horizontal Machining Center which will be used to
machine a cylindrical barrel positioned vertically. There are 12 holes
patterned on the circumference of the barrel and there are 3 such patterns
along the length/height of the barrel. I hope I have been able to make
myself clear! Will PMO suffice or should they go for CMO in order to machine
this sort of part?
TIA,
Niloy Guha
