Round tool ProE WF5
ptc-5020391
Round tool ProE WF5
I need some support here
Is there a solution for my problem? I have attached a picture with the different radius and a ProE-part for you to look at.
I'm supposed to make all sharp edges round, but the radius are different for every edge.
If I for example make the radius 10,5mm and then select the one supposed to be 9mm ProE selects all way round.
Just add all the different radius in a single round feature.
do the 3 and 9 radius first
next do the 8.5 radius..when you do the 8.5 below radius it will select the complete loop, press shift key and select the origial 8.5 edge
then in the end do the 10.5 radius.
Yes you can in round tool there is there is option for adding new set having different values.
Thanks for your reply!
