Route cables>Follow Cable HELP
abesau
I can't figure out how to follow cable in Creo 2.0.  It used to be so simple in WF4!!!
Can anyone shed some light?  Options are Cable to follow: <pick wire>
From: <what does the system expect?> To: <What does the system expect?>
I pick a location from and a location to but yet it does not work.
I can successfully route it manually picking each location point, but it will just not follow it!!!
Any videos out there??
gkoch
(To:abesau)
In Creo the From and to should always be defined first (e.g. by logical data or by manually selecting) - only then different methods to route are available.
You can add locations or use other means, like selecting to follow network / other cables.
