I'm Having a issue using Shell command in Creo 1.0. i'm not able to shell the product it shows the error
Highlighted surfaces are too curved to offset by specified value.
Recommended actions:
Make a quilt from good surfaces, offset the quilt,
make patches over missing surfaces.
But i assure you the product can be shelled I Have already done to similar item to this. Can you guys help me shell the component. If not can anyone Explain me how to do the RECOMMENDED actions told by Creo. I've attached the part file.
Your model is a little convoluted to simply move the "insert here" bar. What I am saying about the rounds applies even with your argument.
If the shell can successfully make the offset from the outer surface to the inner surface, no problem. But if the outer round has a smaller radius than the thickness of the shell, it will fail because it doesn't know how to "exclude" the round on the inside and hem the newly created unrounded seams.
Therefore, I agree that I would want to detail as many features as I can before the shell. In reality, within Creo, it just doesn't work well that way. The slots you have along the side edge, for instance, need to be modeled after the shell.
Best practice for shell is to lay out the basic shape; test the shell; add feature that may work with shell and test again. At some point you will realize the limitation.
As for making the part from a surface and providing an offset and ending up with an enclosed volume is a great way to do complex parts. I do not work on these often enough to make a habit either way. Personally I like working with solids from the beginning. It is easy to solidify surfaces into the solid for doing complex trims.
Creo is quite touchy with Shell. Remove the smaller details and Shell the basic shape. Rounds too can fail Shell if the radii are too small. If the radius exists on the outside, it must be able to exist on the inside with the specified shell thickness.
Thanks for the reply.
I suppose I could do what you told i'm giving the radius before the shell so that when it shells i'd have an even wall thickness (it's plastic part) hence shelling in the pre-formed design would be waste.
Can you tell me how to do the Recommended actions told by creo
Thank you
I will make a basic shape shell and go on from there.
just some more info I've attached a similar design with those slots shelled just thought you'd like to know.
Thanks for the Amazing quick replies
Thanks for the Amazing quick replies![]()
Bravo! Very nice work.
