SMT_DFLT_BEND_RADIUS
PierrePatenaude
3-Newcomer
Hello gang !
I am trying to link the value of the sheet metal parameter SMT_DFLT_BEND_RADIUS with either a value set in a Family Table or with a value entered in the File Parameters. Is that doable?
Any other suggestion on how to manually set that value before entering the bend feature (such as in Templates)?
Thank you.
1 REPLY 1
Hi
you can do this through relation.
write a relation as per your requirement in your sheetmetal template.
The following is a sample
if smt_thickness==1
SMT_Def_BEND_RAD=1.5
endif
if smt_thickness==2.5
SMT_Def_BEND_RAD=3
endif
Regards
K.Mahanta
