SOLUTION - A blast from the past.
TerryJohnson
2-Explorer
Apparently this was some sort of really freaky pro glitch.
Solution: I deleted the radii made it square corners..&  managed to save
the sketch.
I created a second sketch and  started it with square corners and it
stayed in the new sketcher. (like it should) but if I went to edit the
first it was still the old sketcher.
I went back to my assembly to look at it again and one of the parts was
mysteriously missing.  (I didn't delete anything, it was hidden when I
left the assembly, but when I went to unhide it, there was nothing to
unhide.)
So I exited pro updated the assembly and opened it all up again.
but my first sketch was now all screwed up. When I opened it, it was back
in the NEW sketcher but
had made all kinds of new assumptions and I had to do it all over.  The
new sketch did not revert to
the old sketcher again.
Hi Terry,
It sounds as though youhad opened a model that was created pre-WIldfire. An option you have is to regenerate and save them with the config.pro option LOGICAL_OBJECTS set to YES. This will update any “legacy” features to the Wildfire feature scheme. Hopefully this suggestion will provide a benefit forour users who encounter this situation in the future.
Doug
