SOLUTION: How to thaw Frozen Tables in Wildfire 2.0?
unknown1
Carol pointed me in the right direction. And after analyzing the users
trailfile I was able to reproduce the frozen repeat region table problem:
When you remove a Model Rep from a drawing (File -> Properties -> Drawing
Models -> Remove Rep) Pro/E does not warn you if the Rep is used in a repeat
region by a table. It just freezes the tables.
The confusion then starts because you can still show your balloons on a
drawing view (Table -> BOM Balloons -> Create Balloons) which is set to
another rep (this can normally not be done).
When you re-add the Model Rep to the drawing and re-assign the rep to the
table (Table -> Repeat Region -> Model / Rep) the bom table becomes unfrozen
again.
This has been checked on Wildfire 2.0 M160 and M170.
Thanks for the replies.
Olaf.
_____
0 REPLIES 0
