START PART TEMPLATE
ptc-5052803
START PART TEMPLATE
How to create start part template?
2 REPLIES 2
Anand,
template part is regular part. Therefore you can create in the sane way as any another part.
Martin Hanak
Martin Hanák
Dear Anand
If you need to create/use your custom template for start parts, you can start from default file (solid, scheetmetal, assembly, etc.)
Then, you can set custom name, relations, parameters, layers etc. and set configuration option for your start parts.
Here is the example (config.pro options):
template_sheetmetalpart D:\...\start_models\start_shmt_4kside.prt
template_solidpart D:\...\start_models\start_part_4kside.prt
template_designasm D:\...\start_models\start_asm_4kside.asm
template_mfgnc D:\...\start_models\start_mfg_nc_4kside.mfg
template_mfgmold D:\...\start_models\start_mfg_mold_4kside.mfg
Vladimir
Best Regards,
Vladimir Palffy
