SUMMARY: Relations To Control Flexible Inputs
Dan_Harlan
Thanks for all the ideas and input. I think Janet's response was the
most elegant;
Using a parameter called ANGLE that you store the input angle in, and
dim_angle which is the angular dimension being controlled:
dim_angle = floor(ANGLE / 90.0) * 90.0
HTH
Janet Grove
John Deere Power Systems
TomU
(To:Dan_Harlan)
If you're going to use a parameter then give it a restricted parameter definition. That way the user will get immediate feedback on non-allowed values during input.
ND_ParamDefArr_K01 = {
{ Name = Angle
Type = real
Default = 90
Enum = {0, 90, 180, 270}
Tom U.
