Save assembly as .jpg .tif .pdf , there is a line in middle of image
DOVANLE
2-Explorer
When I saved an assembly or part as typical image files (.jpg , .tif, .pdf etc...), there is a "line" in the middle of image.
Is there a way to remove that line.
Thanks in advance.
DoVan
4 REPLIES 4
dschenken
(To:DOVANLE)
Never mind - it finally downloaded. It's not a line, but a failure in the image processing as if it lost track of which part is being rendered. The parts look OK in the reflection surface, so I would look at setting that affect accuracy and look for interferences between components.
I would also look to see that the 'room' is taller than the assembly, though that's probably not it.
If I had to make the picture I would try the parts separately and see if that made a difference to try to narrow it down to one part.
I might also make a small change to the camera position.
DOVANLE
2-Explorer
(To:dschenken)
Thanks David for respond quickly.
I've tried "bigger room" setting or just a single part, still does not fix.
The interested thing is the "line" location is moving down depends on dpi setting and paper size when I exported (100dpi to 600dpi and A to variable ).
At 100dpi, there is no "line"
Any ideas David?
dschenken
(To:DOVANLE)
I think I am stuck. If you add the version of Creo, whether it is academic or commercial license, and what operating system and graphics card this may help others to see a solution. If possible uploading a sample file might help others reproduce the problem and try various solutions.
Does this image defect appear on the screen or only in the saved image?
DOVANLE
2-Explorer
(To:dschenken)
The screen looks good. just save images have problem.
I have the same feeling that system or graphic card play big role in this problem.
I've been using Pro-E for 20 years (commercial license) and Creo 3.0 is current version that produced defect images.
I appreciated your effort David. I will try to up load the models to see anyone can help to resolve this problem.
Have a nice weekend.
