Save coordinate system with part (STEP)
hpham-2
I can create CS on the part (for example: connector with CS located at pin 1) and save it as pkg.  Save part in STEP does not save the CS, is there work around?
PeterKehoe
(To:hpham-2)
If you use the "Granite" option when saving a STEP file, coordinate systems that are attached to the model are included in the STEP file as a wireframe part with a line in each of the 3 coordinate system directions starting at the coordinate system's origin.
Is there way to get the axis label also ? Like xyz.
PeterKehoe
(To:hpham-2)
I haven't found a way to get the labels.
Hi.,
do you know the "The right-hand axes rule"
For explanation start the help of Modeling or Express6 an search for "Orientation and rotation".
in German: "Ausrichtung und Rotation"
Best regards
Friedhelm
(Please write info in your Signature) Sysinfo: I use Creo Elements Direct Drafting, Modeling and Express 6-8-9 ( formerly CoCreate- SolidDesigner and Drafting or ME10 )
