Hello , I am accessing the Schematics , it has an icon to download the libraries that navigates to another site that appears bar , when I click on it I go to another site where I browse to download this Library that says that free gives error in the same , Site all the time this giving error, nor access page.
Virtual Interconnect - Component Libraries main page (virtual-interconnect.co.uk)
Do you have a license for newer versions? If so, I recommend going to 7 or 8. A lot of things have changed since 4.
Are you using Schematics 4 or Schematics 4 Lite? Lite is a try out version and does not support use of libraries.
Unfortunately, I have never seen this "online" library item. The usual way is to build up your library on a local (usually a network location that all your users can see) drive.
I would suggest putting in a ticket with PTC or browsing in their support documents. They may have a very old document that discusses the "online" option.
Virtual Interconnect is a vendor that does contract work in Schematics along with selling libraries and some add-on programs.
You can also build your own library (we do) so that the components look exactly like you want them to.
"I still haven't found a solution to the problem" Has anyone experienced this?
Could you please provide a direct link to this library?
Good morning, follow direct link as requested
