hello again
I want to assemble screw and fasstener
how i do ?
creo/proe have library with those?
must to draw screws? or existing in library?
if exist where is?
i suppose proe have a module separate its true?
/thanks
the best way to learn is to ask
sorry for stupid question
In Creo 3 there is finally a built in library of parts. It is a Lite Version of Intelligent Fastener Extention.
See this item:
http://communities.ptc.com/thread/55956
As it seems to not play well with Windchill. But if you don't need that, then it should work fine.
There are many web sites that let you download hardware files. There are some 3rd party links in the Creo browser also. There are also a few libraries posted in this forum. I prefer to create my own for consistency.
See this item:
In Creo 3.0 M020 we have extended the allowable out of the box parameters to include additional Windchill and Model check parameters.
I hope this will go some way to improving the integration of the free version of IFX with Windchill.
The additonal parameters are as follows
"PTC_MODIFIED"
"PTC_ORGANIZATION_ID"
"PTC_WM_VERSION"
"PTC_WM_LOCATION"
"PTC_WM_TEAM"
"PTC_WM_REVISION";
"PTC_WM_PART_NAME";
"PTC_WM_PART_NUMBER";
"PTC_WM_NUMBER";
"PTC_WM_NAME";
"PTC_WM_ORGANIZATION_ID";
"PTC_WM_ITERATION";
"PTC_WM_LIFECYCLE";
"PTC_WM_LIFECYCLE_STATE";
"PTC_WM_IS_DRAWING";
"PTC_WM_PART_REVISION_FOR_DRAWING";
"PTC_WM_PART_STATE_FOR_DRAWING";
"PTC_WM_CREATED_BY";
"PTC_WM_CREATED_ON";
"PTC_WM_MODIFIED_BY";
"PTC_WM_MODIFIED_ON";
"PTC_WM_LAST_CHANGE_NOTE";
"PTC_WM_LIFECYCLE";
PDMREV
PDMDB
PDMRL
PROI_REVISION
PROI_VERSION
PROI_BRANCH
PROI_RELEASE
PROI_MODIFIED
!MODELCHECK
MODEL_CHECK
MC_ERRORS
MC_CONFIG
MC_MODE
Thank you and PTC for due consideration of this oversight ![]()
