Searching for a hole feature
ptc-5471878
7-Bedrock
I got a yellow error while regenerating an assembly. It said Hole_105 lies outside the model or something to that effect. My problem is I don't know how to search for Hole 105.
And a side note, when I hit regenerate again that error doesn't come up again since my assembly has a green light. How should I make the assembly do a full regeneration so I can see the error again?
to find hole - you should do as at the image below. select your HOLE 105 and move to the right, close search window. having still hole selected RMB > Locate in model Tree (available only in part mode)
regards
gucio
Krzysztof
Look in the message log or the trail file to better locate the problem.
regards
gucio
Krzysztof
