Sections not showing
okaraali
7-Bedrock
Hi guys, I am trying to use the blend tool and as you know it will ask for a sections then you do your thing and it makes it happen. however when I go and press Section the little drop down menu dose not aper and I cannot then use the feature. when I split the screen so I can see all windows on my desktop I shows the window is open but when i go and select that sections window it still dose not aper. Any ideas?
Hi Omar,
Just to clarify, the Sections tab is not accessible, in the Blend dashboard.  Is this correct?
Amit
