Select Volume Region for Max Prin Strain Measure in Creo Parametric Simulate 2.0?
danderson
Please confirm that it's not possible to select a Volume Region in a part for a Simulate measure of Max Prin Strain while in Creo Parametric Simulate 2.0 (m120) ?
Trying to use a volume region for a feasibility study where a strain measure tied to a volume region.
This selection works in Creo Simulate 3.0 but appears not to be available in Simulate 2.0
Don Anderson
346gnu
(To:danderson)
Don,
I cannot in 2.0 M100
I can in 3.0 M060
Looks like a Creo 2 limitation.
bfn
Charles
7 REPLIES 7
346gnu
(To:danderson)
Don,
I can in 3.0 M060
bfn
Charles
danderson
(To:346gnu)
Charles,
The only way I found that I could do it was to first assign the volume region to a layer and then select the layer for the measure.
346gnu
(To:danderson)
Don,
Nice one.
Perhaps you should mark yourself as correct and get the star for tenacity?
danderson
(To:346gnu)
Hi Charles,
It appears that selection by layer fails to work. The measure fails to report any values during the analysis.
Have you found a way to tie a strain measure to a volume region in Creo 2?
Looking like I will have to bounce back and forth between Creo 2 and Creo 3 for this project.
Don
346gnu
(To:danderson)
That's intriguing.
I managed in 2.0m100 using your layer method. See below.
I should have chosen a model that I could hand calc. I have no idea whether the measure is a sensible value.
Model attached if you want a look.
danderson
(To:346gnu)
Hi Charles,
I will need to look into this further. My analysis involves using a non-linear analysis with a non-linear material.
Changing yours to non-linear and it still works so there must me something else going on with my model.
I will investigate further and get back to you on what I find.
Thank you for looking at this so quickly!
Don
346gnu
(To:danderson)
No problem,
A welcome distraction from a particularly troublesome study.
