Hi guys, I am trying to use the blend tool and as you know it will ask for a sections then you do your thing and it makes it happen. however when I go and press Section the little drop down menu dose not aper and I cannot then use the feature. when I split the screen so I can see all windows on my desktop I shows the window is open but when I go and select that sections window it still dose not aper. and one point the window sis show but It was huge had to drag it along over and over just to find the button Any ideas?
Don't worry guys i found out how to do it
