Semantic Text Verify--Model Check
CM_10790883
I am using Creo Parametric 10.0.4.0 and performing a Model Check on a part and I am looking at the warning for "Annotations with incorrect surface references" which has the name ANNTN_SEM_REF_TEXT_VERIFY.
It is telling me that I have the incorrect number of annotations with incorrect surface references.  I am trying to indicate that there are two surfaces that are 1.450 away from datum B, so in the references, I have datum B in the "first dimension reference" and then the two surfaces in the "second dimension reference."  So why is Model Check flagging this?  Am I doing it incorrectly?image.pngimage.png
please open Case at PTC Support.
Martin Hanák
ModelCHECK doesn’t accept multiple surfaces as a single “second reference.” Each semantic dimension or annotation must reference exactly one valid surface per reference. If you try to bundle multiple geometry items under a single reference, ModelCHECK sees that as ambiguous or unstable.
I tried to simulate the case. It works perfectly without any modelcheck error.
Check the following....
  • Angle between the bottom and the highlighted surfaces. (it should be zero)
  • Distance between the two surfaces that are included in the second-dimension reference. This too should be zero.
I see that you are on Creo Parametric 10.0.4.0. I am on Creo 10.0.9.0. Updating might help.
I tested this in 10.0.9.0 and the issue was with the 2X.
When I removed the 2X and replaced it with the continuous feature symbol or "multiple surfaces" under the dimension, modelCHECK had no issues.
I am not strong enough in GD&T to know if this is because of a ruling there or if it is something on the Creo end involving the actual count of how many 1.45" dimensions there are in the model.
