Is there a way to set the drawing default hatching to use model hatch? I have not seen anything in the config or DTL file to allow this. We are using Creo 9.
Hello adbarkcity
Please add following config option in the active model.dtl 'default_sketcher_hatch_spacing = <>
You can edit the active model.dtl from tabs mention below.
File > Prepare > Model Properties > Detailing Tab > Details option <Change>
Please let me know if this works for you.
