I am not aware of any config options to support your objective. There are Creo Toolkit apps sold that are made to apply colors: Rule-based color coding with SMARTColor - B&W Software
If your requirement is not sophisticated, then you may be able to handle semi automation of this process using layers and rules without buying additional software.
I haven't already had the time to create the mapkeys but if u 'll be able to obtain a good result please share the mapkey
Hi @MB_9203282 ,
It appears that this https://community.ptc.com/t5/3D-Part-Assembly-Design/Setup-color/m-p/988952#M137700 answers your question. For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
