Shading issue Creo 1
John.Pryal
Hi all,
i have just installed Creo 1 & have spent the last day or so getting a feel for it. I am concerned about what i am finding whenever i shade a model, there is a rather strange shadow being cast onto the model which moves around as i rotate the model. Am not sure if this is some new enhancement which can be turned off or if it is a graphics card issue. I am using Windows XP Pro with a NVidia GeForce 7600 GT card, am there any known issues with this set-up.
John
10 REPLIES 10
KrisR
(To:John.Pryal)
An image of what you are seeing would be helpful to diagnose the issue.
John.Pryal
(To:KrisR)
Hi Kris,
Hi Kris, hopefully this image shows the shading issue i have.
KrisR
(To:John.Pryal)
It does sound like something in lighting. It may be the "default" lighting settings that you may not be accustomed to.
John.Pryal
(To:KrisR)
Hi Kris,
that's what i'm nervous about, hopefully there is some way of configuring this lighting, to make this same as it has been for the last 10 years. I really don't like this as it is, the image i gave was jus a quick example to show the problem, i work quite often with small intricate surfaces & rely on the shading & meshing to get good surfaces. Hopefully, that makes sense.
John
KrisR
(To:John.Pryal)
The only thing that I can recommend is doing a search for "lighting" in the help file for Creo. I run W5 and I think Creo is quite an update to this module from W5.
Kevin
(To:John.Pryal)
Are you using Shaded with reflections? If so, try just shaded which should be the same as WF5 and earlier.
John.Pryal
(To:Kevin)
Hi Kevin,
yeah, i tried that, but the problem persists.
John
Kevin
(To:John.Pryal)
Guess it could be a card or driver issue. I have an 8800 GT and this doesn't appear on my setup except for the shading with reflections. I tried adding different ligthts as mentioned below and I didn't see anyhing cause what you're seeing.
John.Pryal
(To:Kevin)
Thanks Kevin,
i am making noises about getting a new computer here, so we will see. I don't know what your place of work is like, but here production rules, they will think nothing of spending tens of thousands on machining centres, but spend a few hundred on a computer, & someone might have a heart attack.
John
papendha
(To:John.Pryal)
Is the "shadow" look like a dimple in filleted areas?
I notice that a light added to default room that might cause this.
