Hello All,
Can anyone be able to explain me about the bend tables in Creo2/ProE.
If need to edit the tables as pe rmy requirement of Galvanised Steel 2mm, 3mm & 4mm
Thnaks.
Hi Mirza,
I just responded in the other thread not realizing you had already creating a separate discussion.
Here is some helpful documentation:
