Sheetmetal Bend Table
ErikZabokrtsky
Is there a way to assign a default Bend Table when converting a regular part to sheetmetal? This is what an Engineer sent me and I'm unsure where to look to apply our default Sheetmetal Bend Table automatically...
"Normally when I create a sheetmetal part it uses the sheet metal table to generate the bend allowance. But if you start with a regular part then convert to a sheetmetal part, it uses a different table or formula. I have similar parts bent the same but forming dimensions are different due to the bend allowance from a standard part vs. a converted sheetmetal part."
0 REPLIES 0
