Sheetmetal Miter Flange
- May 14, 2021
- 1 reply
- 3447 views
Hi Members,
I am currently playing around trying to learn CREO, I have done a little bit of inventor in the past. Although quite similar there are obviously some differences, I'm sure you experienced lot will be able to point me in the right direction.
The problem I'm having is when I create a sheet metal flange via sketch (please see attached example), it automatically miters but leaves the deformed area intersecting. Obviously this will create problems when manufactured.
Is there any way to automatically cut this excess material out via the sheet metal tools as opposed to manually creating a sketch and 'cutting' material away with the cut/extrude feature?
Thanks Heaps!!!
