Sheetmetal Quality Check
Ketan_Lalcheta
I am new to sheet metal. Could any one please let me know generalized check points on need to take care?
Regards
Ketan
4 REPLIES 4
Not sure what you are asking.
I am looking for some sort of list which one can refer before sharing creo files with others. This list is kind of quality check. For example, Part file should not have supressed feature Etc..
No suppressed features.
All features are positioned so they will unfold to the flat pattern.
Bend radii are properly defined for material thickness.
Corner reliefs are constructed so the model forms.
Look at the ModelCheck settings to see what it checks for sheetmetal parts.
Most of the things to check for are common sense.
I hate getting or reviewing models with suppressed features and a warning that some cut is outside the geometry.
If the feature isn't needed, delete it!
If the cut is off in space, what is it doing and why do you need it, delete it.
Keeping models clean and simple makes it easier to share them.
Hi Ben Loosli,
Thank you very much for this.
I will go through model check. It will be helpful to me if you can explain more about check point 2,3 and 4.
I know importance of K and Y Factor. But I am not getting how to apply it into creo designing.
Some tutorial or help document will be more useful to me if it is available for proper designing of sheet metal.
Thank you once again for this.
Regards
Ketan
