Gurus...
I need to get your valuable input on which of these techniques to use;
Sheetmetal parts typically require you to show a developed view of the part (flat pattern) before it is formed (bends added).
As far as I'm aware, there are two ways of accomplishing this;
1. Create a flat pattern as your last feature and suppress that flat pattern so your part appears in its formed state in the assembly. Now you create a family table instance, and add the flat pattern feature to the table, and resume the feature for the flat instance, which you then show on the drawing / dxf, etc
2. Create flat pattern, create a simplified rep that excludes the flat pattern. Now you have a rep of the formed and flat model.
I grew up with the family table method, however I am at a stage where I have had it with family tables, and want to avoid them where I can.
Is it worth to switch?
Your thoughts please...?
Cheers
Norman
In Reply to Norman Luyt:
Gurus...
Cheers
Norman
Number 2 but we create an Unbend plus a Bend Back feature in the end. The Bend Back feature is excluded in the Flat Simp Rep state. We want to have the formed part as the default part.
The Flat Simp Rep is added to the Combined states under the All tab. Display Combined Views are checked. This means that you can toggle between the formed part Default All and the flat.
Secondly when you add views on the drawing the Select Combined State window that pops up will let you choose wether to show the formed or the flat part.
There's quite a few steps creating all the Reps so we have a mapkey for this.
