Sheetmetal help needed...
A.DelNegro
I'm trying to build a pyramid shaped cap that I will eventually put a
hole in to join to a tube. When I go to make the 3rd bend, I get the
error "invalid bending area" which I assume is associated with the weird
angles at the tip of the pyramid. Anyone know how to make this work?
The goal is to be able to give the shop a flat pattern that is at least
close to what I want without them having to weld 4 panels together.
The part needs to look something like the bottom image. This was made
with 4 pieces and is close, but not really what I wanted.
Thanx.
Tony
A.DelNegro
(To:A.DelNegro)
OK, the initial best suggestion was to add a relief hole to the
middle... duh! This worked, now I get the funny overlap at the last
two edges. Is this just a trial and error sort of thing? Do I just
tweak the angles till I get it right or is there a secret to it?
In the mean time, I am trying the make a pyramid, shell it, then rip it
method.
Thanx for the quick help.
T
I would make the final shape first, shell, cut breaks and bend relief,
then import to sheetmetal.
It's the difference between modeling a part in 2 hours or 20 hours...
Best regards,
Frederick Burke
A.DelNegro
(To:A.DelNegro)
Thanx to all who responded (and so much quicker than PTC help would
have, sorry PTC...)
THE solution is to create the pyramid, then convert to sheetmetal using
a shell feature. Awesome result. 'zackly like I wanted!
You guys Rock!
T
