Sheetmetal roll bend
joe_c
Folks
I cant seem to unbend this tube. Not sure if is possible with the head on top.  I was able to create the rip. I like to create the hole and the notches at end but I hear is better to create them after unbend. Please help me...CAD was made in Creo2.0
StephenW
(To:joe_c)
You can unbend with the head, as you said. Sheetmetal only works for straight bends, press brake bends or rolling type operations.
joe_c
(To:joe_c)
Stephen
Can we bend the open end of this cylinder inward? is this not possible as well? I suppose first create a rip and then bend it. But wont let me pick the edges
StephenW
(To:joe_c)
You can use sheet metal module to model these things but you can't generate a flat pattern using sheet metal. The parts you are making are not made with a press brake using a straight bend(s). You would need forming dies or coining dies to stamp these parts.
You can roll a cylinder and make a flat pattern, but you can't have the endcap if you want to create a flat pattern.
