Show an assembly with components in different position
cspinelli
hello,
i have a question: is it possible to add a relation in an assembly that rules different positions of a component?
thanks
you can use relations, if component position is defined using dimensions.
Martin Hanák
2 REPLIES 2
Typically this is manages in family tables.  Powerful stuff!  ..if not sometimes frustrating.
Also consider flexible assemblies where a part/subasm can be modified at the next level assembly, such as post machining results.
Martin Hanák
