Hey, I wanted to ask if anyone knows which settings increases the distance between automatic dimensions. I am trying to pick the ones I need but they are just stacked on each other. I was trying to search through drawing settings and test every config named "offset" or having some value but couldnt find anything working. Cleaning up dimensions working okay, but I need to be able pick them out first.
There is no setting to spread out the shown dimensions. To get fewer dimensions on the screen select the feature/features you want to annotate on screen or in the tree. This will only show the dimensions for the selected features.
vs.
Not solved. Looking like complete mess.
