Can I configure a Drawing repeat region (bom table) that shows parent assembly on first line followed by only first bom level components? Recursive table shows parent at top but shows all bom levels. Flat table shows first level bom only but does not show parent at top. I am using Creo 9.0.2.0
set Recursive option and add following Filter
&rpt.level <= 2
&rpt.level <= 2
Works perfectly. Thank you Martin.
