In CREO 5;
How do you show annotations (e.g. axes) by drawing view for one component in an assembly? There is a right-click option in the model tree to show dimensions by drawing view, but not annotations. Thanks.
@wbottis wrote:
In CREO 5;
This shows axes in all drawing views, not just the desired drawing view.
I tested your problem in CR5.0.5.0. I am able to display axis in single view.
I recommend setting the following config option. It makes showing annotations a lot easier. You don't have to select a component to show annotations. You can select the assembly and choose what to show for the components. Video attached.
show_axes_by_view_scope all_sub_models
Ty
