Folks,
I have added an image (decal) to a part surface. How do I show this in the drawing? Is there a layer that the image reports to that may be hidden? Thank you.
Bill
Have you tried a shaded view?
If you're using a Windchill environment, I believe you have to use the config.pro setting save_texture_with_model yes and use a shaded view in the drawing.
